Thread: CYA Pool Calculator
    CYA Pool Calculator
    I have a newly re-plastered pool. I add 4.5 lbs or 72 ozs of CYA. The pool calculator with my given pool size shows that an addition of 68 oz required to bring CYA to 30ppm. I test CYA with Taylor kit and get something considerably under 30. Completely filling the vile past the 30 mark... or something less than 30, the dot is still very visible. HMMMM.... Thoughts appreciated.
    JC
    17,000 gallon gunite in ground pool, white traditional plaster
    1 HP Hayward Super II, 48 SQFT Hayward diatomaceous earth filter, Sta Rite Max-E-Therm Heater 333btu
    Rainbow Chlorinator (on vacation only), Polaris 380, Hayward Colorlogic 4.0 led, Poolmiser Auto-fill
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: CYA Pool Calculator
    When did you add it? It can take a week to show up in the test.
    Other options would be you bought 50% concentration CYA (which has been reported lately) or underestimated pool size.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Three weeks ago. Are you saying that reports are that some products are less strength than the packaging states? I will check the size of pool again, but don't think it could be that far off. I will retest in a few days. I still have the package the CYA came in and will check the label.
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    How did you add the CYA, via the skimmer or in a sock?
    The package said: Add directly to skimmer. I don't usually read or follow instructions well but this time I did ... no sock.
    JC
    Did you backwash or clean the filter anytime in the week following adding CYA? CYA added through the skimmer sits in the filter, where it can take up to a week to dissolve. If you backwashed/cleaned the filter during that period some of the CYA would have been lost.
