Thread: Salt level vs. chlorine production
    Aug 2009
    Close to Houston
    25
    Does salt level affect chlorine production? If so, is it significant enough to have to adjust how much you run the SWG?
    18' above ground from Leslies
    Hayward sand filter (100 lbs) with 50 lbs Zeosand
    1 HP pump
    South Central NJ
    3,192
    Re: Salt level vs. chlorine production
    Salt content matters. Yes, you should check it. Too little and the cell can't pass enough current and the voltage increases but current drops. Too much and the opposite can happen. Water velocity and water temperature through the cell have something to say in this as well. They are designed to function within a range of these and other parameters.
    Watching what is in it it, knowing where it should be and how to get the water inexpensively there is what BBB is about. Pool School is the place you learn the things you need to know. It works.
    Scott
    Owner of - PoolGuyNJ LLC
    Most SWGs are designed to produce the same amount of chlorine across a range of salt levels, typically +-500 ppm from their ideal level. When you go outside that range they may get more or less efficient or they may shutdown completely. There are a few SWGs where the chlorine production is directly proportional to the salt level, but they are getting less common these days.
    Aug 2009
    Close to Houston
    25
    Thanks guys, just trying to figure out how important the salt level is. I'll just keep it within the range.
    1 HP pump
