Thread: Question about Intex SWG system
    Im thinking of buying one of these and i read in the pool school that you need to run pump for atleast 8hrs. Is that the pump or the Swg generator. Most people said that they only need to run generator a couple hours a day to keep chlorine right.
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Re: Question about Intex SWG system
    It all depends on the relative size of your pool and your pump. A large pump for a small pool might only run two or three hours. A small pump for a large pool may need to be run 24 hours a day. It is the same thing with a SWG, the larger your pool, the longer you need to run the SWG.
    I was just wandering if in the pool school under swg setups where it says to run pump for minimum of 8hrs did that mean my filter and not the salt water generator. Reason for asking this is if I ran the sWg for 8hrs I would think it would produce to much chlorine. A little confused with this part.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    You will need to experiment a bit with the Intex SWG to see how well it will work at what timing amounts. The requirements will also vary with weather conditions, rain, heat, etc., and pool use.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    It states "Run your pump a minimum of 8 hours a day and adjust your cell output so your FC stays between 3-5 ppm."
    This is really oriented toward the higher end SWGs...but your pump will/should run independent of the SWG. You basically set the intex swg to run for a certain # of hrs during your pump run time.
    For intex SWGs it only runs at 100% for the # of hours you set it and it turns on at the same time every day, unless there is a power outage. I personally just follow the non-swg FC guidelines for water chemistry, except for CYA which I keep at 60-70. My pump runs for 6hrs per day and my intex swg runs for 3 hrs. Unfortunately with the intex, you don't get chlorination over a long period of time...it comes in 3-4 hour bursts
    ok that explains what I thought. is that a problem the 3-4 hour burst
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
