Thread: Would Slime Bags help with Iron?
    Aug 2008
    Honolulu
    429
    In the post "Dealing with scaling/stain during pool season " "Slime Bags" are discussed would they help with removing iron in solution, or when topping up the pool?
    They I believe will filter down to one micron.
    http://www.cleanerpools.net/slimebag.php
    Thank you to those that reply.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Re: Would Slime Bags help with Iron?
    Iron in solution will pass right through. Iron that has crystalized out and clumped will be filtered efficiently, but clumping isn't all that common and can often be caught by a normal filter.
    A slime bag is very handy if your water source has particulate matter in it.
    Aug 2008
    Honolulu
    429
    Jason,
    Thank you for the quick reply.
    Well there goes another idea.
    Aloha.
