Thread: Water Softener?
    Jul 2008
    Yorkton, SK, Canada eh?
    13
    Water Softener?
    Hi all, learned lots here in 2008 with my first AG pool, now I'm setting it up again after having missed a season (fell off a roof and broke my shoulder/arm last year). I had horrible iron problems last time around (well water) and really hoping to avoid the brown water. My water goes through an oxygen injector, then an iron filter. Last time it also went through a water softener but this year my softener is broken. I'm wondering if that is going to cause me big grief with the pool? The iron filter is good enough that for regular household use I don't need the softener so haven't bothered to get it fixed, simply bypassed it.
    What do y'all think? Should I start filling right away or spend the time/money to get the softener fixed first?
    Thanks!
    Peter Sherwood
    18x48 Bestway (Intex) Easy Set AG
    1500gph cartridge filter pump
    Well water extremely high in iron :(
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Water Softener?
    Perhaps have the fill water tested to see how high the iron count is without the filter?
    (on an unrelated note, please check your pms )
    Jul 2008
    13
    Re: Water Softener?
    What about calcium? I think the iron filter removes the bulk of the iron, but I'm not sure if I need the softener to keep the CH down.
    Peter Sherwood
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Water Softener?
    Could be; if there's a pool store near you, you could have them test the fill water. But...if I'm reading this right, you had horrible iron problems 2 years ago, using the iron filter plus water softener? If that's the case, I would expect the exact same thing.
