Results 1 to 10 of 10
Thread: Wanda has Gone off the Deep End!
    I just set up the pool, and LOVE my wanda the whale, it's a great little cleaner, and my wife accused me of having an affair. ;->
    The issue I'm having is that I have a deep end in the AGP, and due to the steepish angle, she's sort of just "hanging out" there, more so than other areas of the pool, so the pool isn't getting as clean.
    Is there a method most folks use for this? I've tried starting her up on the other end, but she finds herself there soon enough. I've considered putting some sort of physical block on the bottom of the pool, or bungy cording the hose.
    Thoughts?
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    South Central NJ
    3,192
    Re: Wanda has Gone off the Deep End!
    How deep? Wanda wants a flatter bottom. She doesn't climb hills well.
    Scott
    Owner of - PoolGuyNJ LLC
    6', but the drop off is fairly significant since it's a 15x30, and goes from 52" to 72" fairly quickly due to the straps (buttress free.) I tried starting in the middle of the pool and adjusting the output jet, and it did seem to help.
    Richard
    Temecula, CA
    I'm having the same problem with a IGP in addition she keeps getting stuck on the drain. I was told there is a "adjustment" knob on the bottom of the cleaner but I have yet to find it.
    I wonder if she's losing the "push" factor when over the drain as the water flows differently?
    In your case, an easy solution would be to just use your vacuum pole to drop something heavy "over" the drain (assuming you can shut it off independently). I'm thinking of something like a 5gallon bucket with a bunch of holes drilled in it, but enough weight (rocks, etc.) to hold it in place so she'd divert around it.
    Interestingly, better suction from the pump today, and she did way better.
    Richard
    Temecula, CA
    Have you tried the "throat in VS throat out" I havent yet as I've only had her a week.
    Quote Originally Posted by APrime
    I'll have to google that. I did notice a HUGE improvement in performance when I finally got my sand filter all cleaned up. I don't think I was generating enough suction. She's really scooting all over the place, probably 3x as fast now. I have a 1.5HP pump, so not sure if that makes a difference, but I think it was largely a suction issue.
    Richard
    Temecula, CA
    I tried the "throat out" and her movement was very slow, lethargic @ best, she still wont climb out of the deep end so I bought some lenghts of 2" round PVC and a couple of "T"s for the ends drilled a bunch of holes in it and partially filled it with gravel (not very much) now I have a rail across the bottom of the pool to keep her in the shallow end until its clean then I made some small rectangles to go around the drain so she dosent get stuck while cleaning the deep end. She's a geat little cleaner for the price.
    Cool, that's a good idea.
    Can you also just bungee the hose at a certain point to keep her in the area that way?
    Richard
    Temecula, CA
    Just an update. Just did this with a quick temporary setup, and it's working great! I'll build a little gate for her out of some left over pvc. I found if you size it, no need for the heavy stuff, you can just drop it in and wedge it slightly.
    Richard
    Temecula, CA
