Results 1 to 9 of 9
Thread: What makes CH climb?
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    What makes the CH climb in a BBB pool and will it ever stop?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: What makes CH climb?
    CH will rise if you add products with calcium such as cal-hypo.
    CH rise through normal evaporation and water replacement if your fill water has high calcium.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Apr 2010
    Fleming Island, FL
    431
    Guess I should have added more information. I have a SWG, so my chlorine comes from that. I do not have a lot of calcium in my supply water, maybe about 150 ppm or so. My pool is new though and is a pebble finish. Could this be it?
    Carlos
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, the curing of plaster will add calcium hydroxide to the pool which will not only increase pH, but CH as well.
    Apr 2010
    Fleming Island, FL
    431
    Any idea about how long this curing process can take?
    Carlos
    Mar 2007
    San Rafael, CA USA
    12,082
    The first weeks to month are the fastest, but it keeps curing at a possibly noticeable rate for 6 months to a year. After that, it's usually not that noticeable though it still technically cures very slowly.
    CH of 150 in your fill water is significant. No calcium is ever lost through evaporation. Then, when you top off the water level, you are adding new CH. Unless you never add water to the pool, the CH level will continue going up every time you add water.
    Apr 2010
    Fleming Island, FL
    431
    Not what I wanted to hear . So at some point, maybe CH 600 ppm, I am going to have to start diluting the water by drain and fill? Is this normal maintenance to have to reduce CH every once in a while?
    Carlos
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Once the curing slows down, with fill water CH of 150, it would take 3 full pool volume evaporations for your CH to rise that much...your talking maybe 4-5 years and even CH of 600 is manageable, as long as you keep your PH below 7.8 at all times.
