Thread: Taking salt cell to PSS for testing question
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Can I still run the pump when taking our salt cell to the PSS for testing? Last night at my request hubby removed salt cell & is taking to Leslie's today. Presuming it's dead (after various troubleshooting steps still no sign of life), we will need to purchase replacement. I found a 40K online for $350 at poolsupplyworld.com (Leslie's wants $650 for a 40K). So if I order online, it will take, say, a week to get it and get it installed. I don't want to not run my pump for a week, shudder at the thought.
    So do I just set my Aqua Rite toggle to "off" and let the pump run as normal?
    Thanks in advance!
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Taking salt cell to PSS for testing question
    Yep, just put the dead cell back in and chlorinate with bleach til you get the new one up and running. No problem at all.
    If the cell is actually out, you can't run the pump. If the cell is installed, but turned off, you can run the pump.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Thanks Jason. I called hubby on my lunch & told him whatever he did, don't leave the cell @ Leslies...do not let go of the cell....bring that baby home. He flipped the main power switch for the pool equip so the pump is not running.
