Thread: Low pH; high TA
    Low pH; high TA
    Hi All,
    This is Day 2 of trying to adjust the pool balance; yesterday I added stabilizer so that I could get the chlorine at a good, more or less stable level. Thankfully, this morning, FC was at 3.5 and CYA at 38. But my concern now is a combination of low pH and high TA. Here are the numbers:
    FC: 3.5
    CC: .5
    TC: 3
    pH: 7.0
    TA: 175
    CH: 230
    CYA: 38
    Temp: 78F
    I've read on Pool School about aeration, but it also seems to suggest that with a high TA, the pH level will also tend to rise (on its own?). Can anyone suggest a good way to get the pH up to norm, and the TA down?
    best,
    David
    11,500 gal. rectangular cement, 11 x 28 (built c1930); Hayward S180T sand filter; Hayward Max-Flo II 3/4 HP pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Low pH; high TA
    Aerate. Get in and splash around, aim the returns toward the surface, or install a return fountain. Or just wait.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Low pH; high TA
    pH will rise on its own; aeration will speed up that process. Your TA isn't too bad, so if your pH doesn't rise annoyingly fast, you may be happy just adding acid whenever it gets high; TA will gradually go down this way.
