Results 1 to 11 of 11
Thread: Finally doing it myself
    Jun 2010
    Ripon, CA
    5
    So after 12 years of always having a service do our pool we have decided to do it ourselves and thankfully I found tfp. I just got my TF100 yesterday and here are the results:
    FC 10
    CC 0
    TC 7.5
    pH 7.5
    TA 330
    CH 1170
    CYA >100
    Scaling is definitely a problem with the water in our area. This weekend I am going to test the tap water. Looks like I will be draining soon mainly to lower the cya. Not sure I have any hope of lowering the CH without another source of water.
    I have been reading this site for about a week now and I want to thank you for all of your sound advice.
    ~14,500 gal - Jandy CL460 Cartridge - IG - plaster
    Pool built 1997
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Finally doing it myself
    Welcome to TFP.
    You sound like a candidate for Reverse Osmosis water filtering. This service is provided in the Southwestern US where calcium is a significant problem. I'll PM you with a vendor that might be able to help you.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    also...there is something funky going on with your chlorine results...how did you arrive at a TC of 7.5 with FC at 10? Just making sure you are testing right
    Jun 2010
    Ripon, CA
    5
    Oh sorry my bad i tested before adding bleach and then after so the after was 10 and the before was 7.5 forgot to update the tc.
    Pool built 1997
    Guest
    From the looks of those numbers, the pool service wasn't doing you any favors
    Good job finding this place! Once you get your water back where it should be you will love the help and advice here that will allow you to keep it looking great!
    Have you owned the pool for all 12 years, and has it ever been drained?
    Jun 2010
    Ripon, CA
    5
    Yes we have owned the pool all 12 years and it has never been drained. Would something like what you offer (if available in our area - central california between modesto and stockton) be of benefit to us?
    Pool built 1997
    Guest
    If you have R/O in your area, it would definitely be a great option. Do you have an idea what your TDS level is? How about your feed water levels?
    Your CH level is probably one of the highest I have seen (we just completed a Jr. Olympic pool that had TDS of 11,700, and the CH was "only" 640!), and your CYA is probably much higher than what you are able to read (I see the > symbol, so I know that is a redundant statement!), and R/O will remove both of those.
    12 years, at least down south of you, is a very long time to keep water. We have, prior to utilizing R/O, always recommended a drain and refill every 2-3 years to maintain acceptable water conditions. Hard water is definitely a nemesis of the pool industry!
    You are definitely on the right track by being on the 'page! Keep asking questions and you will have your pool looking sharp in no time!
    Jun 2010
    Ripon, CA
    5
    Quote Originally Posted by simicrintz
    Wow I didn't realize that. I don't know what my TDS level is. Thanks for the tips. Nothing pops up in my cursory search for R/O in my area. In the mean time it looks like I will be maintaining high fc levels - i guess its lots of reagents
    Pool built 1997
    Guest
    The good and the bad of R/O is that it is not widely available (yet). It works, and it saves water and gives back a better product than the water company can often provide. It is just more common to dump water and refill, as that is what the industry has been doing for years. A lot of people, like you, were never told they needed to watch these levels, so they did not know. It is only once you find this page that you can start to understand why these all interact, and really take control of your pool. You are seeing that first hand
    Did you plug all of your numbers in to the Pool Calculator yet? That will help you with where you need to be with your FC to try and keep you clean!
    Jun 2010
    Ripon, CA
    5
    Yes, fabulous tool.
    Pool built 1997
    Guest
    Stick around here; you're gonna do just fine
