Thread: sunheater s601 questions
    Hi
    Im thinking about installing some Sunheaters in our inground pool and am trying to find out a couple of things.
    Is there a maximum number of collectors that you can have plumbed together?
    Could you have them on a rack that had them working vertically, instead of horizontally? I am trying to get away with only having to build one rack.
    Elle
    176000
    Sand Filter
    Above Ground, Vinyl
    1.5 hp Hayward Power Flo LX Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: sunheater s601 questions
    Usually there is a limit due to flow issues, but it will vary by manufacturer.
    I don't think most panels are suited for a vertical mount. The weight of the water would put a strain on the panels, and the vertical installation wouldn't be as efficient as a more horizontal installation due to the low solar gain in the middle of the day.
    New Brunswick Canada
    819
    I have 3 - 4'x20' panels plumbed inline on a sun room roof. Works amazing, and you have to love the free heat.
    I can get a 10 degree gain on a nice sunny day.
    If I made modifications, I would build a rack system, that can be moved as the angle of the sun changes as the months roll on.
    April, I can swim easy when the sun comes out for two days, this april, pool went from 64 degree's on a Tuesday, to 81 wednesday night. I think that is due to the angle of the sun in early summer, in the fall, I don't get very much increase as I believe the suns rays are deflecting off my panels and not truly being absorbed. If I could crank the angle up, then I would be ok.
