Thread: replacing a Korky auto-fill
    Hi, I'm totally new to owning a large pool. I have managed to keep the chemicals in balance but it seems like my autofill is constantly filling. Water bill for a month is $163 and it keeps climbing. I would like to either turn it off or replace it. I live in NV and evaporation is really high. I have my solar cover to help with that but I need to either fix or replace that auto fill. Can anyone tell me how to do either.
    Thanks
    Terry
    24x40 Vinyl IG Mountain Lake (100,000 Ltr)
    Sta-Rite Max-E-Pro (1.5hp)
    Sta-Rite System 3 Cartridge Filter (S8M150)
    Jandy Lite2 Heater (400k BTU)
    Zodiac SWG (LM2-40)
    Hayward Phantom
    South Central NJ
    3,192
    Re: replacing a Korky auto-fill
    While I am not familiar with Korky, most standard auto-fills have a toilet tank like float valve that screws in. Check it's operation and it's on/off levels first.
    Seal the port to the pool from the filler. If the filler's float is too high, the drain port will continue to drain excess water. Lower the float's height some and listen for incoming fill water. Check for anything causing the the float to get hung up on.
    Scott
    Owner of - PoolGuyNJ LLC
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Is there a chance you might have a leak and that's why it's constantly filling?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Somewhere nearby, you likely have a ball valve that controls flow to the autofill. The pool builder had to tap into the house plumbing someplace, and would have certainly installed a valve to control it. The first place to check would be at the nearest outside hose spigot, but it could be elsewhere. If you can't find a valve or lower the float, in a pinch you could probably bend a coat hanger and use it to prop up the float high enough that the flow stops. That's what I used till I figured it out, since my float valve was corroded and couldn't easily be adjusted.
    There are a couple possibilities as to why it runs all the time, but that much evaporation is unlikely, even in NV; in Tucson, my autofill runs a little each day, but nothing I would describe as constant. Do you have an overflow drain on your pool? If the float is set too high, as Scott suggested, you could be adding water via the autofill and losing it via the drain simultaneously. Or, as Flyboy320 mentioned, you could have a leak. Either one of these scenarios would knock your chemistry all out of whack, since you'd constantly be replacing water. Are you seeing that?
    Jul 2010
    northern California
    235
    Quote Originally Posted by Melt In The Sun
    We have been having this problem but did not know it until recently. The auto fill kept filling and the drain kept overflowing. How do you lower the plastic float? Does anyone know where I can find a picture that shows how it should be installed? Ours was broken and we replaced it earlier this year. Apparantly, it was not installed correctly. I finally turned off the water supply to the auto fill since it is now winter and it will rain often.
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
