Thread: 18x48 Intex pool - recommend sand filter pump??
    We have an 18x48 metal frame AG Intex pool. Our water quality for our small town is horrible and we have rust sediment in the bottom of our pool with crystal clear water on top- we know it's rust because we get the same thing in the tub when we take a bath. We have a 3,000gph pump model 520 and I'm wondering if we were to purchase a new- higher efficiency pump with a sand filter would that filter the rust out?? I know the pumps that you get with Intex are not very good for the size of pool. We would like to get an upgrade. Does anyone have any suggestions? And like I said, would a bigger pump with sand filter catch all the rust. Our current one now does not so it just circulates
    Thanks for any advice!!!
    AG 18x48 Intex metal frame / 6,700 gallons / vinyl / cartridge filter / 3,000gph pump. New (hand me down) pool owner!!
    Re: 18x48 Intex pool - recommend sand filter pump??
    I dont think a filter can remove rust, at least not one that would be affordable. You can add a metal sequesterant for iron. As far as the pump and filter go I would keep the one you have, untill they must be replaced.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
