Thread: Easy set pool Surface skimmer?
    My surface skimmer does good on my 18foot intex easy set pool. I thought of running it all the time but was wandering if it would filter water on bottom as well.
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Re: Easy set pool Surface skimmer?
    No one knows
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Lots of pools only have skimmers, so I imagine it would be OK.
    pool looked great today. I just was wandering if only water on top would get filtered. Kind of stupid thought o guess.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Your pool return flow should be mixing up and turning the water over enough that what's at the bottom doesn't stay there long. This can sometimes be a challenge in Intex pools due to the pump/filter system deficiencies. Watch to see where debris collects when the pump has been running - more regular brushing or more time with the vac may be needed to clean up and turn over bottom water
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    i usually just get a small pile of debri in middle. nothing bad at all. i can scoop it out in 10 sec with net. i aim the return nozzle the opposite direction of the inlet and down so that it makes a circle persay.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
