Thread: Where do I get Borate strips?
    Where do I get Borate strips? I was in Leslies today and the guy never heard of using Borax in a pool.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Where do I get Borate strips?
    Quote Originally Posted by jimbo65
    No need to test for borates, unless you plan on adding enough to acheive 50ppm...if so TFtestkits.net has them
    I find it hard to believe that decent test kits and borate strips are only available online. Does anyone know where these are available at brick and mortar stores?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Believe it...call your local pool stores and see if they carry the Taylor K2006...they usually carry the Taylor K2005, but it not the same and you'll be missing the FAS-DPD test..the K2005 has the DPD test and is NOT the same.
    Leslie's is the only store that carries a repackaged Taylor K2006.
    The TF100 is by far a better value and the owner of TFP (Duraleigh...aka Dave) owns TFTestkits.net...you will not find better customer service in a brick and mortar store...the same stores that give most of TFP members shady pool advice.
    here is a comparison and the only kits we recommend purchasing
    http://www.troublefreepool.com/pool-...kit_comparison
    There certainly are some pool stores that carry a full range of test kits, including things like borate test strips. However, they are few and far between. None of the large chains keep these things in stock throughout the chain, though individual stores may have things that others do not.
