Thread: Installing a Booster Pump
    May 2009
    Topeka, KS
    81
    Can someone post a pic or link to how to install a booster pump in an existing pool?
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Installing a Booster Pump
    It may be more work that it's worth. Do you have a suction/return line for the booster to use? You may be better off just getting a good suction cleaner or robot.
    May 2009
    Topeka, KS
    81
    I do have a pool heater that I plan to remove. It has piping with ball valves, I thought I could put it there??
    Oct 2009
    3,899
    You need a separate return line for the booster pump; installing it in place of a heater in an existing plumbing loop won't get you the effect that you need. At your equipment pad, do you have separate lines for your returns? If so, you can probably convert one of them to a cleaner line without too much difficulty. If not, it's almost certainly not worth it. Can you post a pic of your equipment area?
