Results 1 to 9 of 9
Thread: Gunite Showing Through Plaster
    Jul 2007
    Alamo, CA
    187
    There are a couple of spots in my pool where the Polaris has worn the plaster through to the dark-gray gunite underneath. I'll take a picture and post it when I get a chance. The worst spot is about 8-10" in diameter in the shallow end at the base of a wall. I asked at Leslie's about this and they told me this product would work to fix it:
    A+B Epoxy Putty
    A PB told me it wouldn't work and that I should get it fixed ASAP as the gunite is not watertight. He says the rebar in the gunite is probably getting exposed to the water, which is now salt, and is likely corroding inside the wall.
    We were thinking of resurfacing the pool this fall, but finances may dictate that we wait until next year. What do you think?
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Arizona
    924
    I think you'll be safe to wait if you have to.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    30,431
    Can you confirm it's not a stain? Pretty unusual for the polaris to be capable of that but, if the plaster was applied improperly (too thin) that would certainly do it.
    The gunite is more porous than the plaster but the water not gonna" gush out. I do agree that it will need some attention and I do agree with the PB that epoxy would be a nasty-looking and probably ineffective fix.
    Assuming it's not a stain, I would talk with a knowledgeable pool plasterer and follow his suggestions. A masonry "patch" may be very effective and would be the least noticeable....still not invisible, tho.
    Jul 2007
    Alamo, CA
    187
    I snapped a couple of pictures this morning with my phone. It's definitely the gunite showing through.
    It seems that no matter how I adjust my Polaris, it gets hung up on the edges of the steps. The leading edge of the cleaner's base "snags" on the plaster and it just undulates back and forth until the auto-reverse kicks in and pulls it free. If I was a designer at Polaris, I'd put a roller along that leading edge to prevent such a problem.
    The color variations in the plaster are not algae...It's just really old. There are smooth patches that are a somewhat greenish tint and the rest is just really rough. The Polaris's bag is always filled with white sparkling sand from the disintegrating plaster. I am overdue for a replastering, but that's several thousand dollars I don't have lying around right now.
    blubluenoiseise
    Arizona
    924
    You will be fine. I've seen worse than that and she held water just fine.
    Buggs
    Jul 2007
    Maryland
    89
    Interesting post. My Polaris gets hung up on the steps as well. New plaster to boot (45 days new). Anyone else experience a wear issue or could it be cause of older plaster?
    BTW, I tgink a roller on the front of the Polaris 360 would be an excellent idea.
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Butterfly's Avatar
    South Carolina
    10,045
    I will try to attach two pix of our pool before we got it cleaned up and BEFORE our replaster. Needless to say, we did not know this 'thing' was there......exposed gunite. At the deep end, under the light (poor pix, sorry) you can see a black line. It was appx 6 to 8 FEET long and 6 inches at the highest point. FYI, we did NOT detect any leak or water loss, but the PO did leave a POLARIS tossed up uder the deck.??? We have not found it necessary to use the Poalris because, I am almost afraid to say, we have not needed it. It is now stored in the basement. There was no problem w/the step area, but they did have a line of tile on them, now replastered over. Now, that said, we have no idea if the Polaris had anything to do w/this or the PO dumped his chems there and did not brush, etc., or a combo of both? Who knows. Mainly wanted to let you see that our huge exposed gunite area did not seem to bother anything last season and it made it thru the winter just fine. Hope this helps. Happy swimming, Joyce
    You're done SLAMing when:
    Man, if those photos are from before you cleaned it up, what does it look like now??? it is lovely!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by The Mermaid Queen
    Sorry about that , this was AFTER it was cleaned up & balanced w/BBB , but BEFORE the replaster! The before clean-up pix are on the "Show off your Pool/Spa..." section, but you can't see the exposed gunite in them. Thanks for the correction, Grace.
