Results 1 to 12 of 12
Thread: Wondering if CYA drops more rapidly in really hot climates
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    I'm beginning to wonder if the CYA level is somehow dropping more rapidly in pools in really hot climates like Texas. A friend of mine has been using pucks to chlorinate his pool for years. He does the standard weekly shocking treatment with some pool store product. Recently he had a very bad algae breakout and the pool turned green in a couple of days. All he evers measures is Chlorine level and PH. He didn't even know what CYA is. I figured I would use the opportunity to help educate him on the effects of high CYA. When I tested his pool, his CYA level was 60. This is a pool that is open year around with pucks used for sanitizing 24-7.
    In my own pool in Houston, I use bleach primarily but also use pucks when I'm out of town. This spring my CYA level was low and I used a lot of pucks while my CYA level rose. However, it didn't rise nearly as fast as the Pool Calculator said. I bet I added 30 pucks over the course of the spring and my CYA rose about 20PPM.
    Is there any information of other potential ways CYA could drop?
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    busbeepbeep's Avatar
    Jul 2007
    New Orleans, LA
    24
    Re: My CYA seems to be disappearing
    Woodberg, my pool is really hot Louisiana is having similar problems. I've added enough stabilizer to measure about 60ppm in my pool (8lbs), but still only seeing 20-25 ppm on my test. (Tried both TF-100 and HTH 6 way)
    17,000 gallon in-ground plaster (circa 1985) | Tagelus 60 Sand Filter | Whisperflo WFE-3 3/4 hp (1.25HP/1.67SF) | 1.5" plumbing, 17psi normal | TF-100 Test Kit | Liquidator
    It has been a couple of years, but there have been problems in the past where CYA from the store didn't actually contain any CYA. On other occasions the CYA was actually 50% CYA instead of 100% CYA.
    CYA does break down, but it does so really really slowly. Normally splash out and other forms of water replacement are far more significant.
    Re: Wondering if CYA drops more rapidly in really hot climates
    Is your ch also dropping ?
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Woodberg's Avatar
    Apr 2009
    136
    All of my other numbers are stable. In my case, I would have just thought that my CYA would have increased more dramatically from using the number of pucks I used. In my friends pool, he is exclusively using Tri-Chlor pucks and yet his CYA was only 60. He does backwash occaisionally but not enough to to keep the CYA that low.
    In my case, I have a cartridge filter. I have some splash out from the kids swimming but most of my water loss is evaporation which shouldn't reduce the CYA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Could dilution be occurring from rain overflow? According to this link you seem to get rain all year long in every month for a total of around 48" (4 feet) per year. If the rain is just filling up what is evaporated, then that shouldn't dilute the water, but if the water overflows from the pool, then dilution would occur.
    The oxidation of CYA by chlorine is probably dependent on the temperature of the pool, but we keep our pool warm at around 88ºF and such oxidation seems pretty slow at around 2 ppm CYA per month, approximately (but our pool is covered during the day except for 1-2 hours). Even in hot spas (104ºF), people doing measurements found a loss of around 5 ppm CYA per month. Now it's possible that this oxidation is catalyzed by some sort of other chemicals or metals or occurs more rapidly when there is more sunlight, but that's just speculation at this point. Also, any loss of CYA through this mechanism would likely have a much higher chlorine demand since every drop of 10 ppm CYA would use up around 25 ppm of chlorine. It is known that the oxidation of CYA by chlorine does occur much faster at higher pH so has your pH been higher than normal, say at 7.8 or higher the entire time?
    In my pool the CYA is dropping. I have an abnormal amount of water loss in this 95-100 degree weather due to the waterfall. I don't run it all the time, due to evaporation and the big pump that runs it, but even running it 3x/day to keep the pools chlorinated means that some water evaporates or soaks through the rocks to be lost. And I overflowed once or twice - doh! And then heard the pump acting funny, went over there to find water gushing out of the top of the not totally screwed on automatic chlorinator -doh! So in addition to 4" of rain this month, most of which overflowed, I've added an extra 3 or 4" myself that overflowed.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    woodberg, i've had some issue's as well with CYA disappearing. i did the bucket test and i do not have a leak. i do know i add water every 2-3 days and there is some splash out so that could be part of the problem as well. per chem geek suggestion, just chalk it up to a mystery, add some stabilizer and move on from there. i typically test my CYA every 2 weeks now just to keep an eye on it.
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    May 2008
    florida
    112
    I had the same problem when I purchased the product from Lowe's and that was before the rainy season. I then purchased from the pool store and so far so good and it has been raining every day.
    Apr 2010
    Buckeye, AZ 85326
    619
    Interesting post. I tried switching to bleach, but I changed my mind and went back to the pucks. I'm going to leave the pucks in and see what happens. My CYA is at 80ish as of last night. It's melt your face off hot here right now and will be like this till mid September. My pool gets nothing but sun all day, I have a cartridge filter so I dont backwash. I have a feeling though that backwashing is the key to a TF puck pool.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Shane1, with every 4 of the 7 oz pucks you ought to see CYA rise by 10ppm in an 11,872 gallon pool (per the Pool Calculator, Effects of Adding Chemicals, at the bottom).
    So, unless you somehow lose CYA it will be over 100ppm in, what, 2 or 3 weeks?
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by anonapersona
    Thats the way I understand it. We will get some rains this summer with the monsoons so that will give me some dilution, but then again if I shock with powder it all may be a wash. I'm really interested to see what happens. It does give me confidence to know that if it doesnt work out I can get every thing cleared up with the help form the people of this site....and for that I am thankfull
    2' Powerfall
