Thread: Soapy suds in tub yikes!
    I was recently giving my tub a quick cleaning at the waterline with a Mr. Clean Magic Eraser, which I have found in the past works for this very nicely ( and for many other things too). However I had inadvertently used a "Bathroom" variety which must have some kind of detergent within it. I noticed excessive foaming, almost right away afterward. Is there anyhting that can be done to get rid of the soapy mess? Will it clear with time, or is a drain and fill in my near future?
    Larry
    Freeflow spa "Solstice" 340 Gal, on an outdoor deck at a small cabin by the lake.
    Re: Soapy suds in tub yikes!
    I don't know if adding enzymes (Scumbuster or the like) will oxidize the stuff so it can be filtered out over time or not but I use it on a two-week interval along with a scumball to prevent waterline formation from ever happening.
    Barry
    Sundance Hot Tub 365 gal, acrylic
    (2) 2.5 hp pumps
    ozonator
    Northwest Ohio resident
    I was back up there today, the water is clear, the suds minimal. It does form foam with air on, but it settles quickly. However, the water tastes soapy. ( I figure my kids will all have it in their mouths so I better try it). I just need to find a time now for a drain and fill. Just when I was getting everything all dialed in nicely...
    Larry
