Results 1 to 11 of 11
Thread: immovable iron stain
    30,432
    A friend had a round BBQ grill grate fall into his pool over the winter (undetected) and it has left a nice 24" round imprint of the grate on his pool floor in the form of an iron/rust stain.
    I suggested some vitamin C to see what affect it would have. He reported that, held onto the stain for more than 3 minutes, the Vitamin C had no affect whatsover....Nada.
    I am at a loss as to what to suggest next.....any ideas?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: immovable iron stain
    What is the pool surface?
    Is he using one Vit C tablet or some crushed? If he is using the (more expensive?) Vit C tab with the slick outer coating, it may take longer to dissolve/have an effect.
    I read about the slick outer coating in one of geekgranny=alice's posts and it does make sense.
    You're done SLAMing when:
    30,432
    I'm sorry, it's a vinyl pool.
    Steve told me he crushed up half a bottle of tabs and the whole bottle was only $3.00.........sounds like the cheap ones but I'll confirm about the coating.
    What surprised me most was he said it had NO visible effect. I have used tabs to remove rusty nails stains and it was about 85-90-% effective so I fully expected these to make SOME difference. I am stumped.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Dave, I dropped a fender washer off my dive stand in the pool last fall, and didn't notice it for a couple of weeks. Left a big stain. I took a 2" PVC coupling and placed it over the stain and dropped the Vitamin C tabs into the coupling. Gone the next day. For a larger stain, the coupling could be moved as the stain faded.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by Butterfly
    I just looked in cabinet. The C tabs I'm talking about are "Ester C" "non-acidic stomach friendly" "coated tablets".
    No wonder they didn't do anything to the stain being "non-acidic stomach friendly".
    Our Vet wanted us to give these to the puppies. DH studies up on them and decided we needed to be taking Ester C too.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Feb 2008
    Denton, TX
    5,061
    You know it's a metal stain. That's a given. That being said, I would still try the vitamin C thing. I would either use industrial grade AA or I would find the cheapest most non-coated, hardest on the stomach, Vitamin C tabs that I could find, crush them up, and reapply.
    30,432
    Yeah, I think to retry with a stronger, longer concentration may be worth it.
    A BBQ grill grate might have also have a fair bit of grease and ash on it, which could also be involved in the mark. I would try a magic eraser to see if it has any effect.
    30,432
    Steve says the grate was used for a different purpose than grilling so no grease on it. He is thinking about more vitamin C in a sock but this time using a weight to hold it on the stain for perhaps overnight. I have no knowledge that that will be harmful.....any opinions?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    DLO just did something similar; here's their thread (with good pictures):
    http://www.troublefreepool.com/orang...nd-t22929.html
    30,432
    MITS,
    That's a great thread and totally applicable. I have forwarded it to my friend.
    He and I have played volleyball for years. He knew I was somehow involved with pools so he asked me how to get this stain out of his pool and I said, "Try Vitamin C tablets". Here was his look........
    It was identical to the reaction I get when they ask at the grocery store what all the bleach is for??
