Thread: Timers for a 24 volt operated solenoid operated valve
    I am looking for a dedicated timer to operate a 24 volt AC solenoid operated valve to add liquid chlorine to my swimming pool. The timer must have a minimum increment of 1 min and a maximum increment of up to 60 min. and the potential to activate the valve up to 4 times per day on all days during the week or on alternating days during the week. Is there anyone out there that knows of such a timer, I would appreciate your advice.
    15-foot above ground pool, Hayward Turbo-Flow pump with sand filter, use liquid chlorine, Metchlor Caddy pool chlorinator; Metchlor Caddy also used for automatically adding muriatic acid; winterize with light and water resistant cover.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Timers for a 24 volt operated solenoid operated valve
    Check the timers for sprinkler systems (Rain-Bird, Orbit, etc.). They use 24v solenoid valves to control water flow, and all but the cheapest models can do what you need. Should be well less than $100.
    I've never heard of using one to dispense liquid chlorine though. Can you post what you're planning on doing? I assume you're planning on using a sprinkler valve? Not sure how those would hold up to liquid chlorine...probably not all that well.
