Thread: Blackspot Algae-Need Advice
    Mountain View, Arkansas
    64
    Hello all,
    I switched to the BBB method at the beginning of the summer and you guys have helped me create an awesome sparkling, chemically balanced, and best of all cheap to maintain swimming pool. But last week I started noticing black spots all along the walls of the pool. I have counted about 11 or 12 spots. They are basically all even with each other around the pool. I have taken a brush and gone over them and they will not wipe off. So I have assumed it's blackspot algae anyway. I have began shocking the water at yellow mustard shock level and have brushed twice today. Does anyone have any other advice? I heard this is hard to get rid of and I have closed the pool till I get this resolved. Kids and wife not happy! Here are my numbers:
    TC 25
    FC 25
    CC 0 (Is this possible?)
    pH 7.5
    TA 100
    CA 243
    CYA 35
    Borates 45 to 50
    Salt 300
    Thanks everyone,
    Al.
    Mountain View, Arkansas, 23,000 gallon in-ground concrete pool with a 24-in Hayward Pro-Series Sand Filter with side-mount. Chlorinator is attached but only use occasionally and a 1 hp pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Blackspot Algae-Need Advice
    Can you post a pic? brushing has no effect whatsoever? doesn't sound like BA.
    64
    Here is a picture. I have about 12 of these in the pool. Scrubbing doesn't do anything to them
    Butterfly's Avatar
    South Carolina
    10,045
    Try testing a spot w/a vitamin C tablet.
    You're done SLAMing when:
