Thread: Crackling sound from jet, air in line??
    Jul 2007
    The Right Coast
    23
    This is our first season with a pool. It's a 10K gallon inground with a sand filter. We added salt after reading many positive posts in regards to chlorine pools with salt, and we're very pleased with the results. We love our pool!
    Recently there has been a crackling-type sound coming from the jet near the stairs, and it looks like it might be air coming out with the water. I tried backwashing and rinsing last night, and it did stop, but this morning it started again.
    Any suggestions would be greatly appreciated. Please describe where I will find any parts that you mention in your replies, as I am not familiar with the names of all the different parts of the pool and filter. I hired someone to come out and teach me when we opened the pool, but he was a jerk---took my money and only said 2 (rude) words the whole time he was here!
    Thank you so much!!
    ~Judy in NJ
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Air coming from the return is a sign of a leak between the pool and the inlet of the pump. There is a strainer basket that is at the pump inlet to catch debris. Many times the lid for the basket is loose, causing the bubbles. That's the first thing to check.
    ktdave's Avatar
    Katy, TX
    888
    Also check your skimmers to make sure the skimmer door (weir) is moving freely and that there is no vortex (sucking of air) in the skimmer.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Houston, Texas, USA
    148
    Also if the filter has a relief valve, open it to purge any air inside the filter.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Jul 2007
    The Right Coast
    23
    I checked out your suggestions
    There doesn't seem to be anything out of the ordinary going on in the skimmer basket. So I cleaned off the lid where the other basket is and around the gasket (is that the rubbery part into which the lip of the lid fits?). Then I took the gasket (?) out and I put a fat thread of lubricant all the way around where it goes, then stuck it back in. Right now there's no more crackling sound.
    I will report back later tonight or tomorrow if it returns.
    Thank you all very much!
    I hope you enjoy the rest of the summer!!
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Judy,
    You will want to check that every time you clean out the basket. Make sure no debris is left on the rubber O-ring and that you do keep it lubed as you have just done. Let's hope that was your answer. Good Luck.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
