Results 1 to 7 of 7
Thread: Plumbing for Buried AGP with Pump Above Water Line
    Just finishing up my pool install before I build the deck over it, and I am a little confused on the right parts for plumbing everything.
    I'm good with 2" PVC lines, elbows, etc, but where I get confused is what kind of valves I need for startup/shut down, etc.
    The pumps (one for main stuff, a separate one for the solar setup) will be just slightly (less than a foot ad the intake) above the waterline, but above it nonetheless, so air lock can be an issue I think.
    I'm planning on putting a ball valve on both sides, but how do I plumb everything so I can release the air in the lines on start up and prime it? It's a 1.5hp sta-rite pump connected to a typical sand filter.
    Is it as simple as plumbing in a relief valve into the system? Or is there some other way to deal with it? Obviously, in season, best bet is to shut the valves to keep the air out when doing any servicing, but I'm talking in the beginning of the season, or when ever is necessary.
    What about making a P trap, so to speak, come out of the pool, and make a U before going up and out?
    Thanks in advance.
    Pic of the Locations:
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    Re: Plumbing for Buried AGP with Pump Above Water Line
    You need to use a self priming pump. A self priming pump which will take care of everything you need. Most above group pool pumps require that all of the plumbing have water it in before the pump is turned on. That is impossible to achieve when the pump is above the water level. A self priming pump is able to raise the water from the pool up to the pump even if there is mostly air in the pipe.
    It is often nice to have a ball valve on the supply from the pool and another on the return to the pool, though they are not required.
    Well bummer. I wasn't really wanting to buy a new pump. I have the option to locate the pump below the water line if I carry it out another 10' or so, maybe that's the way to go.
    If it weren't for the solar side, I'd just locate them below the deck and add an access, but I have to run pipe anyway, so it doesn't save me anything, other than $50 worth of pipe.
    Richard
    Temecula, CA
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    May I ask why 2 pumps anyway? I know one is going to the solar array but not sure why the need for a separate pump to the solar instead of diverter valves, either manual or automated? Just asking - thanks!
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Quote Originally Posted by NWMNMom
    No huge reason, actually. I've been running the solar separately since I set it up, and just like to be able to control both "sides" of the system independently. Mainly, it allows me to run the solar pump (a 2500gph intex) at different times/intervals than the main pump. That helps me be able to maximize the solar stuff, and minimize the big pump use (I'm not upgrading to 2 stage until this one dies), and if there's a water quality issue, I could run the main pump all night if I wanted, which I'd NEVER do on the solar side because it cools down to sub-50 and even sub-40 overnight around here, so I have to max out the solar impact. The intex was cheap too.
    Richard
    Temecula, CA
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Ok, makes sense. Was wondering since we have a diverter valve on our plumbing to the solar so if I need to run all night I just open the diverter and it bypasses the solar - we get REALLY cool at night too! Tonight we are forecasted to 45 deg - close the windows!
    Well, now, that would have been easier/cheaper, now wouldn't it? ;->
    I actually still like for them to be separate. I currently have them on 2 different timers.
    I tell ya, I'm currently running 7 2x20' panels on my 15x30' pool (with large deep end), and it warmed it up to swim-ready in 3 days after the well water (50 degrees) fill. I have 3 more that will be put in place once I fix the leaks...
    Richard
    Temecula, CA
