Results 1 to 8 of 8
Thread: TF-100 calcium test question
    I've only had the kit for a week or two and I feel pretty comfortable with all the tests except the calcium test. When I add drops (attempting to make solution turn blue) I notice the liquid part turns blue, but I have pink flakes. Do I continue adding drops until everything is undoubtedly blue?
    #'s (I'm shocking)
    11 FC
    .5 CC
    PH 7.5
    TA 130
    Cal 480-540??
    CYA 15
    I'd really like to get the calcium number down, I did a 40% refill on the pool and it didn't seemed to help much. I tested some water out of the tap and it was 220 (no flakes). The person before me used cal-hypo like it was going out of style, so I assume that is where most of it came from. Is this something to be concerned about, if so, how do I manage it?
    15,000 gallons
    Sand
    IG
    Feb 2008
    Denton, TX
    5,061
    Re: TF-100 calcium test question
    Calcium is not an issue for a vinyl lined pool.
    If the liquid in the sample is blue, then you have reached the endpoint of the test. It is normal to see little globules in there that are pink or violet. All you are looking for is for the sample to be blue.
    Thanks! So it's more of an issue for the pool surface than the equipment, I see. I was a little concerned about the pump/heater. I appreciate the help!
    15,000 gallons
    Sand
    IG
    Normally your vinyl pool could care less about calcium. In your case the calcium is high enough to cause scaling if your Ph and Ta get out of hand. I would change out 40 percent more water, its the easiest and safest option. Your cya is low so at least you won't lose too much.
    Cal-hypo is something no vinyl pool owner should buy.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Vinyl liner pools are fine with low CH levels, but all pools are at risk for high CH levels. You need to either bring down your CH level, or bring down your TA to compensate for the high CH level, fairly soon.
    Thanks for all the input, I'll work on bringing it down. Looks like I'll be doing a couple of refills...
    15,000 gallons
    Sand
    IG
    How much water does it take to keep the vinyl liner down, what is the minimum safe amount of water? 6"?
    If I do a 50% refill twice, I'll get 75% of it replaced (diminishing returns)... I need to replace 85% according to the pool calculator. So if I replace 60% twice then I'll get 84% replaced... I'd really like to minimize the refill without endangering the liner. I'm probably over thinking this... Thanks for the help so far!!!
    15,000 gallons
    Sand
    IG
    To be on the safe side, I would leave one foot of water in the shallow end of the pool. Of course, if there is any chance you have a high water table you shouldn't drain even that low.
