Thread: aqualuminator and Intex metal frame pool
    Does anyone know if the pentair aqualuminator pool light will fit an intex metal frame pool? Will the side walls support the weight and does the hole in the pool have to cut bigger?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: aqualuminator and Intex metal frame pool
    Sorry I can't help!
    Central NJ
    44
    I have the aqualuminator in my pool.
    I looked at the Intex pools online and the sides look soft. I probably would not recommend it. For that type of pool and the size I would be more inclined to get a solar floating light. They light up okay but save on battery replacement. If your looking brighter go with a regular battery type float style. There are many to chose from.
    Hope that helps.
    12X18 AG, 6200 gal
    Hayward S166T sand filter, Switched back to 100 sq ft cart.
    Hayward 1hp power flo matrix two speed pump.
    Been using BBB since pool was new in 2004. Never had any problems.
