Thread: muriatic acid questions
    Jun 2010
    Waco, Texas
    66
    Morning,
    Can anyone tell me what happens to the MA I put in? Does it get eaten by the sun like chlorine? Can you end up overloading a pool with it in effort to keep PH/TA under control? As you can tell I am no chemist but it helps to understand what happens to the products I put into the pool.
    Also, we will no doubt get rain from the tropical storm in the gulf. At the very least scattered T storms. How does rain affect PH ordinarily and specifically for pool water that has a TA that is around 250-280? Is it good for a pool that has issues like mine or will it be a headache?
    Kawfy
    AGP 16x32x52 Cornelius, guesstimate of 15400 gal. Dished out in center to 5 ft , Counter sunk 1ft 10"
    Jacuzzi 1.5 hp pump, 300 lb sand filter
    Full hot sun in Heart of Texas
    Re: muriatic acid questions
    The super simple answer is that muriatic acid turns into salt eventually. It won't turn into enough salt to really matter, so you can essentially ignore it.
    Rain tends to cause the PH to rise dramatically when the TA level is that high. Storms also tend to blow organic debris into the pool, increasing the chlorine demand temporarily. If there is enough rain, the pool might overflow, but that is rare.
    Most pool stores carry this kind of liquid acid. If not they all carry "Dry Acid" of "Sodium Bisulfate". Each pound of Sodium Bisulfate is the same as using 10 ounces of Muriatic Acid in pool water. A good way is to work out how much you need carefully measure it into a bucket, then take the bucket to the pool and lay t in the water the acid will run out with no splashing that way. Just use your sense.
    30,000 Gallon IG pool, vinyl, Aqua-rite T-cell 15 SWG, 1 1/2 HP with Tagelus TA60D sand filter 60 gpm
    You will want to be careful about putting in too much MA at one time, you need to be certain that the amount you add will not drive the pH too low as that can damage the pool and equipment, possibly creating stains also.
    My understanding of the mechanics (someone will correct this if it is too far wrong) is that the MA first lowers the pH, this consumes some TA, then the pH slowly rises due to aeration which drives off some gases in solution leaving TA where it lowered to.
    In general, just use enough MA to get the pH into the proper range. pH 7.5 is the pH of the eye so you want to be near that for comfort and safety when swimming. Therefore the range is something like 7.2 to 7.8. When pH gets to 7.8, use just enough MA to get it back to 7.2 then wait, as long as your TA is high the pH will tend to rise. The more you lower the pH, the more TA gets worn away, eventually it will lower. I you are not trying to lower TA then you just adjust the pH to 7.5 not 7.2.
    In our parts of the country, where fill water has high TA (mine is 340) I always have to add some MA on a varying schedule. Evaporation or splash out makes me have to add water, TA goes up, pH goes up, I add MA, pH goes down, TA drifts down eventually, then I have to add water again. I guess if I had to empty the pool and start all over with tap water at TA 340 I might be aggressive about trying to lower the TA using the acid & aeration method. I have done that in the past, but I have developed POP (Pool Owner Patience) and so now I just add MA as needed and track the TA weekly.
    I believe that rain will have very low if not zero TA (barring alkaline dust storms?) and so heavy rains will tend to lower TA through dilution but only if there is a LOT of rain. 2" is not a lot, but 30" over the course of a wet winter may be to the extent that this is in excess of evaporation replacement. In the short term, rain tends to raise pH via aeration. So, I guess if you knew a big rain storm was coming, you could lower the pH to 7.2 then let the free aeration and dilution both work to lower the TA as pH rises naturally.
    Overall, my take on rain is that in the short term, in small amounts like a few inches, rain is of no matter but for debris and possible dirt in the pool. AGP won't have the dirt from landscaping falling in, so only blown in leaves to worry about. Aeration from raindrops will tend to raise pH some amount, probably trivial but perhaps noticeable. Dilution effects would require a lot of rain combined with overflow from the pool.
