Results 1 to 9 of 9
Thread: Not impressed with the pool builder... I'm just sayin'
    Nov 2009
    Cleona, PA
    236
    This is not my pool, but I found it, thought you would appreciate it.
    [attachment=0:16vhgk4a]bobcatInPool.jpg[/attachment:16vhgk4a]
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Not impressed with the pool builder... I'm just sayin'
    Ouch. That's an expensive moment of inattention.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    So anyone want to estimate how much chlorine it takes to oxidize a bobcat?
    Or is that one of those mini-movers the landscaping guys use?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    That's the new robot CatVac. Takes 30 seconds to clean your pool...and no filters to bother with. Comes with a limited supply of vinyl patches
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Nov 2009
    Cleona, PA
    236
    Yea, I'm hoping it's a cement pool. Tile or Vinyl might be a bit trickier. On the plus side, any oil dripping off the thing would lube the pump!
    Perhaps they were hoping to start an in-pool reef.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I saw this on another thread and suggested metal-out. How many quarts do you think he'll need?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Since I'm under construction, and have faced a few delays along the way, I can honestly say this scares me! Ouch - that would be a very undesirable delay.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Maybe the driver had partaken of too much reef(er)
    Luv& Luk
    -Ted
    Apr 2010
    Western North Carolina
    44
    Where's the post about getting human waste out of a pool... You know the guy that drove that thing in there messed himself!
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
