Results 1 to 8 of 8
Thread: If I shock my pool to a FC level of 24, can we swim in it?
    Apr 2010
    Syracuse, NY
    103
    If I shock my pool and bring the FC level to 24, is it safe to swim in? Thanks.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Feb 2008
    Denton, TX
    5,061
    Re: If I shock my pool to a FC level of 24, can we swim in it?
    It is not recommended to swim with a FC at or above shock level.
    22,543
    It's safe to swim up to shock level for your CYA. However unless you're finished shocking it's not safe to swim at any level.
    Since we don't know what your CYA level is we can't say if 24 is safe to swim.
    Apr 2010
    Syracuse, NY
    103
    Thanks. I was using the suggested shock level of 24 for my CYA of 60. What do you mean when you say, ".....unless you've finished shocking it's not safe to swim at any level" I'm assuming you mean while there's algae in the pool it's not safe to swim.
    22,543
    You assumed correctly. I wouldn't swim until you pass the overnight loss test. Then it's safe to swim with the FC still at shock level.
    Apr 2010
    Syracuse, NY
    103
    OK, thanks!
    Dec 2009
    Central Massachusetts
    2,690
    I'm not sure what you mean here? Why is it not safe to swim in a pool with a algea? Presumably any pathogen is dead since it takes much less chlorine to kill pathogens (most anyway) than algea. Otherwise it's not safe to swim in a lake. Am I missing something?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    In a situation where you are still losing FC overnight, there must be something organic in the water that is still being broken down. Not always, but most of the time, that means there is a place somewhere in the pool where there is zero chlorine and algae still alive. Where ever that is, bacteria and viruses can be alive there as well.
