Thread: How much Fiber Clear?
    The old pump (age not known since it was here with the old pool when we bought the house last summer) started leaking along the top where the bump knob was, so we got a new one.
    I'd like to use Fiber Clear, but I'm not sure how much to use.
    We got a Hayward DE50c90 kit (filter and pump). The manual says 5lbs of DE, but Fiber clear is measured in scoops.
    Going by the Fiber Clear bag, it gives a rating of scoops per filter size. The Hayward manual says the DE50 has an "effective filtration size of 25FT2" So I'm assuming 25ft2 is what I should use when looking at the Fiber Clear bag??
    When adding the number of scoops for 25 square feet filter, the pressure never changes, unlike when I added DE to the old filter.
    How do I know how much fiber clear is enough?
    Jun 2010
    Fremont, CA
    293
    Re: How much Fiber Clear?
    The Fiber Clear website says one 9oz bag of Fiber Clear equals 5 lbs of DE.
    http://www.fiberclear.net/products.html
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    My understanding is that you need to really clean your filter of ALL DE before you add fiber clear. Major issues if you do not do a super job cleaning the grids of DE.
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
