Thread: Jandy Purlink Salinity Calibration
    I have a PURELINK system. I have replaced the flow sensor once before and I know I re-calibrated the system but I cannot find the manual which described the correct
    button sequence for setting the salt ppm level on my AQUAPURE1400. Can anyone tell/give me the proper instructions on how to reset the flow sensor ppm readings?
    Thanks
    Salt Pool - Jandy Auqa Pure Chlorinator
    17000 Gal.
    Gunite
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Jandy Purlink Salinity Calibration
    I'm not familiar with that unit at all; you should be able to find the manual on Jandy's website.
    This no longer a issue.............
    17000 Gal.
    Gunite
