Thread: Relief valve open, DE slipped into pool via main drains...
    I went to add chlorine to my in line chlorinator and also opened the air relief at the same time. Upon returning to the pad from getting the chlorine, i glanced at the pool and saw DE oozing out of the main drains. The pump basket was also full of it and gurgling like crazy.
    I swear i had opened the air relief before but I think that was a bad idea. Not even sure why i did it, but thought that is what i always did. So should i leave air relief closed with chlorinator opened up?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Relief valve open, DE slipped into pool via main drains...
    What model DE filter do you have?
    Luv& Luk
    -Ted
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Makes sense to me. Opening the air relief valve let water flow backwards from the filter to the pool, carrying DE (plus whatever was caught in the DE) with it.
    Quote Originally Posted by waste
    This one.
    http://www.pentairpool.com/pdfs/FNSPlusOM.pdf
    10,000 gallon
    NC KANSAS44
