Thread: just added CYA to pool when can I go swimming
    Just added 2 gallons of CYA to pool. How long should I wait before going into pool
    24,500 gallon plaster i/g
    sand filter (Hayward S-200)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: just added CYA to pool when can I go swimming
    How long will it take you to change into a swimsuit? Seriously.
    If you used liquid CYA, I'd go around the pool once with the brush; that will ensure it's well mixed and you'll work up a good sweat, which will make the cool water that much more refreshing.
    22,543
    Right now!
    By the time you read this and can get out there you'll be fine to go in.
    In the pool aas we "speak" Thanks Guys
