Results 1 to 13 of 13
Thread: Chlorine keeps going to zero
    Just changed to BBB, chlorine has gone to zero twice in last 5 days. What am I doing wrong? Each time I re-chlorinated according to the pool calculator. I 've had this pool for 12 years, and only other time this happened, was when the phosphates were really high. (I live under an oak forest). But tested it for phosphates today, and result was zero.
    Very frustrated! help! Gunite finish. on pool.
    48,000 Gallon gunite pool
    Cartridge filter. 2HP pump
    Runs 12 hours/day
    30,419
    Re: Chlorine keeps going to zero
    Chlorine is consumable. It disappears from exposure to the sun or doing it's job killing organics. It must be replenished on a daily basis.
    If it is diappearing faster than you expect, you may have ZERO CYA or you may have the beginnings of algae in your pool.
    Can you post a set of current test results?
    Sure. Temp: 84. Normally, in the past, I have shocked it once a week, and kept chlorine tabs in pool, and this has been sufficient.
    Here are my values:
    Total Cl: 0
    Free Cl: 0
    Combined Cl: 0 (of course)
    ph: 7.6
    TA: 100
    CYA: 100
    Phosphate: 0
    I think that covers it!
    No obvious algae in the pool. Water hazy.
    Runs 12 hours/day
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    What he said ^
    Chlorine will go down. Period. Either you aren't adding enough, you don't have enough CYA so the sun is destroying it, or you have algae starting. The only way to know is by testing. Test CYA. Test FC, get it up into range, test it again before bed and then again in the morning before the sun hits it. If you have the answers to that, you'll have the answer to your question. And if you can't figure it out, post the results here and someone will interpret them for you.
    Okay. I'll do that. But with the CYA 100, I'm really surprised!
    Runs 12 hours/day
    30,419
    I'm gonna guess just a little but I suspect your CYA level has gotten so high that it has rendered your Chlorine inneffective and resulted in allowing algae (that's the haziness) into your water.
    The only permanent resolution is to drain enough of your pool water down to get the CYA back to 50ppm and then stop using the pucks as that's what has driven the CYA up too high.
    So, with a CYA of 100, it prevents the chlorine from working on the algae? If that is true, what level do I have to get it to. I live in Fla, with days of high 90's, and nights of 80's, so I need some CYA in it. What level do you suggest?
    Runs 12 hours/day
    30,419
    That's a very good starting point....you will not want to get much higher than that and you'll have to give up the pucks for the season.
    okay. I'm glad to give up the pucks....as long as I can keep adequate chlorine level in pool. So I'll need to add bleach nightly, to keep the chlorine level, I'm guessing.
    Runs 12 hours/day
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by abundance56
    It's not so much work, really.
    Troublefree does not mean Maintenancefree. As I posted a few days ago in another thread: it's like brushing your teeth. You can spend a couple minutes a day for pennies a week or go to the dentist and spend several thousand dollars once a year.
    Once you get into the rhythm of things, 2-3 weeks I'll guess, you'll know pretty much before testing what you'll need to add. Grab the jug during a commercial and dump in a quart or whatever it takes. You should be looking at the pool at least once a day anyway, just to be sure it didn't spring a leak and that the pump's not screaming.
    My husband just got home with pool test from another pool store. It says my CYA is 50. I'm going to have to buy my own CYA test kit....the one I have doesn't test it. pool store are closing here in 10 minutes. I'll check back tomorrow, after I buy a kit, as I won't be able to get to store before it closes.
    You are right, a few minutes a day, is much better than this grief every weekend! Thank you for the help! I'll let you know results tomorrow, and what I am going to do. Unreal that two different pool stores will get two such drastic result differences! ugh!
    Runs 12 hours/day
    Richard320's Avatar
    Jan 2010
    18,995
    It would be more unreal - surreal, perhaps - if two different pool stores got the same readings from the same sample!
    As long as you're going to get a test kit with CYA, you may as well go for it all and get the FAS-DPD test, too. Which means, Taylor K-2006 (Leslie's equivalent 81329) or the TF100.
    Just to mention it, most of us here use the TF100. Great value, great service, easy to find advice here since most of us use that.
