Thread: AA treatment
    AA treatment
    just finished AA treatment for metal stains on fiberglass. treatment worked great. i added the AA
    yesterday followed by sequestrant. it has been 24 hours , so i just checked TA and ph. ph was at 7.2, so i will
    leave that where it is. TA was 70, so i added baking soda per calculator to raise to 80. of course chlorine was at 0. My question is at what rate should i bring chlorine back up as the procedure says to bring it up slowly?
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Re: AA treatment
    At first you want to add 1 or maybe 2 ppm of chlorine at a time, pouring much more slowly than usual. At first all of the chlorine will vanish in under an hour. During this initial phase, you can add more chlorine as often as once an hour, but don't bring the FC level above 2 at any point.
    Once you are able to maintain 1 or 2 ppm of chlorine for more than an hour, you want to increase the FC level slowly, by 1 or 2 additional ppm each day, until you get up to your usual FC level.
    Re: AA treatment
    thanks jason
    1 hp hayward pump
    madisonville, ky
    Re: AA treatment
    also, i've added a total of about 20 ounces of algacide during this process. is that enough to keep algae at bay til
    i get chlorine back up or do i need to add more?
    1 hp hayward pump
    madisonville, ky
    Re: AA treatment
    In this situation it is better to have too much algaecide rather than too little.
