Thread: Viewed posts still show as unread status
    Mar 2007
    Houston, TX
    167
    After you view posts they are not changing to "read" status. I have to use the option to mark all posts as read option at the subforum level.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    I am not experiencing that problem. If you would, please update your profile. Even if you make no changes, I have had instances where I have updated my profile and it has fixed some issues I have had in the past. Also, please verify that you are logged into the forum. They are still updating the system and I have had to log in several times today. Please let us know if it continues. Thanks for your patience.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Mar 2007
    Houston, TX
    167
    The problem continues. I updated my profile by changing my default colors to cobalt, then changing back to subSilver.
    I have read the algae diary post probably 10 times. Still shows as unread.
    I'm sure the board style (cobalt default) is because Sean is working on getting other styles back on. Only the default style made the move.
    There does seem to be some slowness with which things 'refresh' since the move, but I am noticing that they are working themselves out (or Sean or somebody is working on it behind the scenes...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    divnkd101's Avatar
    Mar 2007
    587
    I will send Sean a PM on the issue. The Network Admin has been coming on the site as well to look around and will probably notice this post. As soon as we have an answer, we will get back to you. Thanks again for your patience.
    MIKE
