Thread: Filter basket not filling with water
    Hello all,
    For the past couple days when my system shuts off the pump filter basket water level goes down, almost empties. Then, when the system turns on, there is a lot of air sucked through until water finally begins to fill the basket. This results in air bubbles coming from the jets into the pool. I checked the o-ring it is intact, not really any lubricant left on it though. Not sure what the problem could be but I know that air in the system is not good. Also when I clean the basket and try to refill with water it will never fill up. Please help!
    Thanks
    35,000 gal. Plaster, in-ground, Hayward swimclear C4025 cartridge filter,
    5 port polaris cleaning system, Hayward gas heater, spa.
    PhoeniX, AZ
    Re: Filter basket not filling with water
    The reason you can not fill the pump is gravity. Its going to drain back to the pool as fast as you put it in, unless you close a valve on the suction side of the pump. I suspect your pump is just showing some wear. eventually the wear ring will need to be changed or the pump replaced. As long as the pump picks up prime in under say 2 min. you are ok.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Why not lube the o-ring and see if it helps any? Can't hurt!
