Thread: Is swimming safe without proper water chemistry?
    Jun 2010
    NB, Canada
    66
    Hi guys,
    My new liner is in and i have those test strips to test the water. I know the water isn't chemically balanced yet, but i'm wondering if it's safe to swim in. I have a 35,000 Gallon in ground. It's chlorine right now, but i'm converting it to SWG this week. Here are the readings based on the strips (which are hard to read accurately):
    CH - 90
    FC - 2
    Alkalinity - 115
    Ph - 7
    Bromine - 2
    Thanks!
    Re: Is swimming safe without proper water chemistry?
    You need to raise the PH up to at least 7.2 before swimming. Other than that, things look alright for swimming for the moment.
    Guest
    And don't forget that a SWCG is still a chlorine pool
    when you convert from Bromine, I'm pretty sure it's a must to drain the pool first.
    Maybe someone who's dealt with this can verify but, I've always been warned about going from Bromine to using chlorine....salt water system included.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Unless you had Bromine in the water, that test isn't really testing anything, so ignore it.
    The pH might be a little rough on the eyes, but you know, you bathe in that water already, so I doubt it's toxic! Some swimming and splashing will help circulate and aerate things, too!
