Thread: Kind of stupid question
    How do you guys keep the fresh cut grass out of your pools?
    IG Liner
    SWG
    15000 Gallons
    New Brunswick Canada
    819
    I have a bagger on my mower, works like a small vacuum cleaner, rarely get any grass clippings at all.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I have a hose by the deck gate to rinse feet before going in. The pool is an above ground so we don't get grass clippings blowing in.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Tracked in or blown in by the mower?
    Tracking-wise, we have a deck from the house to the pool. Mower-wise, I turn the main drain off before mowing to maximize skimmer flow, then aim the deck opening away from the pool. Still usually get something in there when it's dry and the stuff blows around.
    Mar 2007
    Richmond, Va
    179
    Above ground here - we use a blower to move all grass clippings away from pool area.
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    krcossin's Avatar
    Detroit Burbs
    113
    I also have AG, but I use to work for a lawn mowing company, we would purposely mow in a direction that the discharge was always pointing away from the pool to minimize the debre, then blow the deck from coping edge to grass yard.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
