Thread: Removating Concrete Pool Deck
    Our pool deck is a perimeter of approximately 4ft x 4ft x 10 inch concrete slabs, approximately 550 sq. ft in total. I'm guessing it was put in 20+ yrs ago. We are in Eastern Canada which may explain the 10 inch thickness.
    The four corner slabs plus a couple other have sunk 2 to 3 inches towards the pool. Surface of many have become very rough, discoloured and some cases small pebbles are showing in the concrete.
    I thinking of mudjacking the sunken slabs and then having a 0.5 to 1 inch resurfacing added to the complete deck.
    Could mudjacking damage the pool wall (the part that has to be raised is up against the pool) ?
    Any suggestions, comments etc?
    thanks
    AG 18x33 15700 gal 1hp 22" sand filter
    Dec 2009
    Central Massachusetts
    2,690
    Re: Removating Concrete Pool Deck
    Please explain what mudjacking is?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Guest
    Quote Originally Posted by bk406
    It might be like car jacking (or that might just be in California )
    mud jacking I believe is the pumping of soil/water mix under a slab to fill in a void. I would think that as long as the pool was filled there would likely be no harm.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Here its a cement mixture - they drill holes in the concrete and then pump the mix under the slabs to level them. Sometimes it works and sometimes they settle again... it isn't cheap and the finished look is just ok cuz you have the drilled holes that stand out with cement/crete that doesn't match.
    We've had it done twice.
    I'd be worried about what you can't see and where the mix might end up....
    I've never heard of adding a layer on top of existing. Would it bond properly?
