Thread: Black Powdery stuff in pool
    Hi,
    I changed my pool over to the BBB method from the Perma Salt System back in the middle of May. And couldn't be happier!!! Pretty clear, sparkling water.
    Here's my question: The last week or so we've noticed a black powdery (silt like) stuff in the pool, mainly in the liner creases. If you disturb the water over it, it disperses, it is not slimly. Walls and pool bottom feel great. Any suggestion on what it could be? My husband thinks it may just be stuff our sand filter is not catching. Until just recently it has been very dry, so when he moves it kicks up a lot of dust. I did have some left over Clariate from our Perma Salt days, it is suppose to make particles bonds and filter them out. He thinks it has helped it some.
    Here is my numbers, I try to keep my FC between 4 and 6. I've not done a overnight FC test since May 27th. Will attempt one tomorrow morning, but I hear thunder.
    FC 4.5
    CC 0
    TC 4.5
    PH 7.8 should I lower this?
    TA 100
    CYA 50
    Thank you,
    Carlotta
    Carlotta (aka Clodda)
    Oval AGP 18x33x54 18,000 gal.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Black Powdery stuff in pool
    Is your pool, by chance, downwind of a barbeque?
    Richard,
    Our grill is not close to our pool, and neither are our neighbors. But I will run this question by my husband.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    PH down to 7.4 would be good.
    You can lower the PH now, or wait till it goes up just a little more and then lower it.
    I expect that the black dust is either pollen or blown in dust of some kind. Since it is already settling to the bottom on it's own there is no need to treat it, just vacuum it up every couple of days.
    Apr 2010
    Syracuse, NY
    103
    I had a similar thing recently. Mine was a bluish/black dust on the pool surface, sometimes it was massed together. I thought it might be some sort of insect eggs. I looked very close and they were extremly small bugs. They are gone now. I think the chlorine gave them a headache.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
