Thread: SWG Cell Disassembly?
    Has anyone ever disassembled a SWG Cell? Primarily a Aqua-Rite Turbo Cell T-Cell-15?
    I'm interested in swapping the power modules on them. And possibly breaking the old one down to the point where I can extract the actual cell out of the casing? It would be nice if someone has a little guidance on this as if not I'll just be doing this from scratch.
    Thanks!
    16x32 21,500 gal. inground poly-walled vinyl liner
    1.5 hp Pentair Whisper Flo 2-speed
    Sand dollar filter
    Pool Pilot digital w/SC-36 cell
    Levolor Auto-fill
    2 skimmers, 2 bottom drains, 2 eyeballs
    Re: SWG Cell Disassembly?
    You don't normally every want to do that. If you open up the cell it is unlikely that you will ever get it put back together again.
    The cell and the power supply are in two separate boxes. The cell is installed in the plumbing, while the power supply is in a box typically mounted on a nearby wall or post.
