Results 1 to 13 of 13
Thread: Effect of hot water temperature on chlorine consumption?
    Apr 2010
    Ozark, Alabama
    40
    A little background: my pool gets FULL sun at least 12 hours a day and we've been near 100 for the past month, so the pool water temp is staying well above 90.
    I didn't stay on top of the pool for a couple of days last week, and inevitably I saw the signs of algae starting. I'm not sure if its green or algae, but the yellowish tint of the clouds when brushing tells me that it was mustard.
    So, now I'm trying to shock, but the chlorine levels are bottoming out within hours like I've never seen before.
    Example:
    8pm FC: 27
    10pm FC: 17
    7am FC: 2
    I always bump it back up, but I honestly can't afford to dump 10-15 gallons of chlorine in a day to keep the shock level up.
    I don't have CC when I test, so normally I'd assume that the pool is shocked. However, the water still isn't as clear as it should be and the FC readings would NORMALLY indicate that something is eating the chlorine.
    But, with the water temp still above 90 even after sitting all night, could that be why I can't keep it at shock levels?
    Pool Specs: 18x36 (~ 24,000 gal) IG vinyl w/ chlorinated water and 75 GPM sand filter with a 1 HP pump.
    30,287
    Re: Effect of hot water temperature on chlorine consumption?
    No. The problem is the algae (organics that remain in your pool)
    Unless you bring your FC up to shock level and HOLD IT THERE until your pool clears, (You are not holding chlorine up where it needs to be) you will forever be living with a green pool or forever loading it with chlorine until you get your mind set on shocking it continuously until it clears. Your FC consumption will drop down to normal as soon as you kill the organics.
    You should post a full set of water test results. There may be something else going on that is interfering with the shocking process.
    Apr 2010
    Ozark, Alabama
    40
    Everything else is normal.
    pH: 7.6
    FC: 4.0
    CC: 0
    TC: 4.0
    TA: 150
    CYA: 55
    CH: I don't test for it because I have a vinyl, but this isn't the problem.
    I know how to shock and I've never had to put this much in.
    I thought I saw somewhere that mustard algae requires a much higher FC level, sometimes north of 40 or 50? If that's the case, I'll just get some sodium bromide and deal with the copper content later.
    Your levels look good, except for the low FC level. The more frequently you can add chlorine, the sooner this will all be over. If you allow pauses where the FC level drops down, the algae starts growing back and then you will need yet more chlorine to deal with the new algae.
    Warm water speeds the rate at which algae grows.
    Apr 2010
    Ozark, Alabama
    40
    I understand the concept, just wondering if temperature affects chlorine consumption. Thanks for your time.
    During the day, warm water increases chlorine use. At night the the FC level should remain the same (ie no chlorine used up) regardless of temperature (assuming you don't have algae or some other organic contamination).
    Apr 2010
    Ozark, Alabama
    40
    The problem is that the water temperature never drops more than a degree or two.
    Its sitting pretty at 95 right now and won't go below 92 before morning.
    EDIT: For the record, I understand that sunlight consumes/destroys chlorine. That's not the question I'm asking.
    Then I don't have any idea what you are asking.
    Your first post appeared to show a dramatic FC loss at night. That would not be caused by the water being warm. That is caused by something organic in your water that the chlorine is breaking down. Whatever is happening, it is not being caused by the water being warm, though warm water might be aggravating it. For example, if you have algae, your problem would be that you have algae, not that the water is warm. Now algae grows more quickly in warm water, so it will take more total chlorine to kill the algae than it would in cold water. But the warm water would not be what is causing the problem in the first place, the algae would be.
    Sunlight uses up more chorine when the water is warm than it does when the water is colder.
    30,287
    I am not sure what the question is, either.
    Aug 2009
    North Central Texas
    1,358
    How long are you running your pump and when are you running it?
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Guest
    The title of the thread is "Effect of hot water temperature on chlorine consumption". It appears to me that he is asking if hot water consumes chlorine. While he states that he does (did) have algae, it appears that he is questioning if hot water itself has any affect on chlorine consumption, and, if so, to what extent.
    Did I get that right, LongbowFoSho? Just trying to help you get an answer
    Apr 2010
    Ozark, Alabama
    40
    You nailed it and I simultaneously understand what Jason is saying, lol.
    So basically, the temp of the water itself doesn't affect chlorine consumption, but it DOES promote faster algae growth which, in turn, consumes more chlorine.
    So I guess water temperature does affect chlorine consumption, but only indirectly through the promotion of accelerated algae growth.
    Without an organic in the water, the temp could be 100 and should theoretically have the same chlorine consumption rate as 80 degree water.
    I get it. Thanks for the help, guys.
