Thread: autopilot digital Model # 75003
    autopilot digital Model # 75003 (220V) set in "1 speed pump" is not working. No power on #4, #6 terminals during the programed hours. The load out is connected to a Lorentz AC Power Pac. I've been running all the tests and checked all the fuses. The #1 #2 terminals indicate 220v.
    This device as been working successfully since the last 6 months with no speed pump attached and is now indicating a "low flow" problem.
    Jun 2010
    Lake Worth, FL
    7
    Re: autopilot digital Model # 75003
    Hi pierre,
    Have you check the unit's automatic-flow bypass manifold assembly? The most common problem for "low flow" is a dirty strainer screen. When this gets clogged, the tri-sensor does not receive the proper flow needed to function properly. Good luck!
    Pool: IG 10,200 Gal 15 X 29 Tahiti (Freeform) w/ Spa Overflow built 2004 by Robert Allard Pools
    Finish: CLI Sun Stone Exposed Aggregate in Antigua
    Filter System: 120 Sq Ft Hayward Star Clear Plus
    Pumps: 1HP & 1.5HP Hayward Maxi-Flow
    Salt Chlorine System: Autopilot Pool Pilot Digital SC-36
    Spa Blower: 1.5HP Air Supply Silencer
    Automatic Pool Cleaner: Zodiac Baracuda G3 & PoolSkim
    Heat Pump: AquaCal Heatwave
    Pool Cover & Roller: Klear Choice Solar Blanket & Solar Roller
    Patio: 65' X 25' BetterVue Screened Pavered Enclosure
    Thanks for the answer kentserph, will check that but now my major pb is this:
    Correction about the displayed message:MESSAGED DISPLAYED “CHECK FLOW”
    A check flow message is caused by too little flow past the trisensor. This is most commonly caused by a dirty filter screen in the manifold, exactly as kentserph suggested. It can also happen if your pool filter need cleaning, or there is a blockage in one of your skimmers or the pump strainer basket.
    Ft Lauderdale, Florida
    1,455
    Pierre, if you press BOOST, can you hear the relay making a "CLICK" noise? Are you getting any voltage (AC)across #4 and Ground, #5 and Ground, and #6 and Ground?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
