Results 1 to 8 of 8
Thread: When is it safe to swim?
    MomUv5's Avatar
    Memphis, TN area
    49
    I don't think I've seen this question addressed anywhere on here.
    I saw one post where a forum member talked about not being able to see below her thighs because the water was cloudy. Another member responded that he doesn't swim unless he can see the hairs on his toes.
    Since I've been converting a swamp, it hasn't come up in my house until the last couple of days.
    Right now, my pH is 7.2 and I just added enough bleach to get the FC up to 8, based on my CYA of 20.
    The water is clear and inviting, which is a major accomplishment since I started with a black swamp filled with leaves, sticks, and mud.
    There is a trace of cloudiness that I only notice in the deep end, since we had some algae yesterday. But, I have no problem seeing the main drain.
    Can I let the kids get in the pool?
    Elizabeth
    Newbie with 18 x 36 rectangular pool, estimated at 18,000 gallons, sand filter, inground w/vinyl liner, SWCG
    (Plus a houseful of nearly grown kids)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: When is it safe to swim?
    Don't let them swim unless you can see them anywhere in the pool, bottom included.
    Casey's Avatar
    SW PA
    10,438
    If you can see the main drain, I don't see what it would hurt. You should be fine... just never, ever let anyone swim if you can't see a foot into the pool! It's very dangerous if one should go under, you'd never be able to find them til it's too late! Better to be safe and hot than sorry and devistated.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    ...............and keep that pump running solid for awhile. Enjoy!
    MomUv5's Avatar
    Memphis, TN area
    49
    Hooray! I'm telling them they can get in!!
    Elizabeth
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    My general rule of thumb on other's pools is if I can see the drain we're in or if I can make out the pattern on a liner.
    If it's green, cloudy that we can't see our feet, then no.
    In my own pool, you'd better be able to describe what the pattern of chipping is on my toenail polish or it's not clean enough...kinda on the same lines as seeing the hairs on a toe. I'm just picky that way.
    I don't hold others to the same standard...except the green hair kinda bugs me...my issue.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Apr 2010
    East Texas
    9,591
    Gotta make you wonder if the shade of the toenail polish makes a difference!
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    woody..
    I use "I'm not really a waitress" red by OPI. So, the pattern is clearly visible in my pool and hottub.....lol
