Results 1 to 7 of 7
Thread: should I be concerned
    Apr 2010
    Cache , Ok 10 miles west of Lawton, OK
    37
    Hey everybody, a great day to be a pool owner!! With temps at 102 HOT HOT HOT!!!!
    Any way I have a question. Every day I have some stuff at the bottom of the pool. I have to vacum almost everyday, but must ever other day. At first I was thinking it was algae, my wife says it looks green. I can't tell maybe its brown its hard to say. I did notice where most it is there wasn't much water movement , I'll try to fix that with a fountain I bought on line.
    My numbers are with a tf 100
    FC 5.5
    cc 00 to .05
    TA 100
    CYA around 50
    Ph 7.8 I an lowering that now closer to 7.2
    now I did a over night fc test it was at 6.5 and went down to 5.5
    the water is really clear. Its just I was thinking I should not have to vacuum as much. No tress not to much dirt and dust. Seems when it sooo hot no wind. I have a solar cover, but it makes the pool water even more hot. Should I be concern or am I overly paranoid
    Thanks to all the guys and gals helping on this great pool forum!!!
    Robert Opdyke
    Retired Army and still serving.
    18X54 round above ground pool
    Sand Filter, 1hp pump
    TF 100 Test Kit
    Rover Jr robot cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: should I be concerned
    How many hours a day do you run your pump and at what times?
    Apr 2010
    37
    I have been running it from 2:00 am to 4:00 am and 9:00 am to 9:30 Pm. I just may shock it tonight just too be sure.
    TF 100 Test Kit
    I would try raising your FC level a little higher than where you have it now and see if that helps at all.
    In some areas, dust is sometimes blown into the pool continuously and there is nothing you can do about it except clean regularly.
    Apr 2010
    37
    I am going to raise it to 8. Another question, how low can the fc go and still be effective? Today when I tested around 8 pm it was 2.5 so I lost 3 ppm today. It was hot 103, and we swam for about 2 hours more or less 2 adults 2 kids (hopefully no pee).
    Thank you
    TF 100 Test Kit
    Assuming the FC level only gets low for a couple of hours, you are fine as long as it doesn't go all the way down to zero. If it stays low for a couple of days there can be trouble even if it never gets down to zero.
    Apr 2010
    37
    thank you!!
    I raised my fc to 8 and this morning there was a little bit of brown sediment, but it did not look green also my fc from last night to this morning stayed the same to 8 ppm. Is fc 8 ok or is fc7 better or does it make any difference?
    TF 100 Test Kit
