Results 1 to 10 of 10
Thread: wedding cake step problem.
    Jun 2010
    Dayton, Ohio
    241
    One of the cylider lids that hold the pebbles/sand that weigh down the stairs fell off. Not sure when it happend because the pool was not used for a long time. The result is tiny pebbles all over bottom of pool. Vacuum doesn't seem to grab them. They were sticking so I took a brush the the bottom and loosened them up. Not sure how to get them up. Any ideas?
    Lori
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: wedding cake step problem.
    Try a shop vac?
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    22,542
    What kind of vacuum do you have and how does it connect to the pool?
    A manual vacuum is your best bet if you can get the suction high enough to pick the pebbles up.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If that won't work, I think I would brush them all to one area and just sweep them into a regular old dustpan. This is assuming your pool is in swimming condition though...
    Jun 2010
    Dayton, Ohio
    241
    I have been fighting what I call my snowglobe of a pool. Dead algae I think. But I am getting a handle on it. I can actually see bottom of pool now, which is new. I left pump off overnight and in the morning I could see bottom and decided to vacuum. When I started the stuff shot straight back into pool. Not sure how to remedy that. New filter? I have one on order. I am cleaning the current one like six times a day. how about using the hose to suck up the rocks and not attatch the vacuum head?
    22,542
    Get a skimmer sock and suck them up into it. I wouldn't use the hose end unless it's very smooth and if you do be careful.
    Jun 2010
    Dayton, Ohio
    241
    how do i suck them into a skimmer sock?
    22,542
    Sorry I didn't explain it better. If your vac uses a plate that goes on top of the skimmer basket take a skimmer sock or knee high and stretch over the skimmer basket. That way the small ones won't go thru the pump.
    Jun 2010
    Dayton, Ohio
    241
    ohhh......that makes sense. so vacuum like normal but put on a skimmer sock......thats a great idea.
    Jun 2010
    Dayton, Ohio
    241
    I finally took goggles and hooked up the hose to the skimmer and spent two hours going under finding the pebbles and sucking them up.....I was exhausted. I need scuba gear. It worked though. I am going to do it again tomorrow.
