Thread: Adding chemicals cheatsheet
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    I am a simple person and need all the help I can get. To that end, I have created a "how-to-put-pool-chemicals-in-the-pool" for dummies (me being the dummy, since it is customized to my pool) cheatsheet.
    I would greatly appreciate it if the awesome pool gurus here would glance it over & offer advice/suggestions. There are some gaps because either I didn't find them in Pool School or my search on the forum did not yield results.
    http://pooldrama.tripod.com/POOL_CHEM.pdf
    MANY THANKS!
    Sonflower
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Re: Adding chemicals cheatsheet
    Wow, that looks cool.
    There are numerous trivial mistakes (salt doesn't have to go in the deep end, you can add baking soda in large quantities if you need to, borax has two uses that are essentially unrelated (raise PH, raise borates) which you have somewhat mixed together, Haviland's Salt Support is a brand name for boric acid which is much less expensive if you purchase the generic, I don't bother with gloves when handing muriatic acid while eye protection is critical, and so on). The only one of any consequence I noticed was that you should wait at least a short while after adding muriatic acid before swimming.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Thank you Jason! Appreciate any and all advice. I am really trying hard to get this right.
