Thread: Is all DE the same?
    Is all DE the same?
    I buy my bags of DE from the Riverbend Sandler pool supply store. Is there a difference in DE?
    Thanks.
    Mo
    28K River Sand Plaster Finish - 2.5 HP Stealth Pump - Jandy 60 Sq Ft DE Filter - LAARS LT400 Natural Heater - Polaris 280 - Jandy PDA PS6 Computer Center
    22,548
    Re: Is all DE the same?
    There actually is. There is DE that's processed for insect control and then there's pool DE.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If you got it at a pool store, it should be fine. DE labeled for pool use is processed differently than DE labeled for other uses, so only pool DE will work in your filter.
