Thread: What causes TA to lower on its own
    Lehigh Valley, Pennsylvania
    71
    My TA has slowly lowered itself over the past few weeks. I boosted it up and overshot to about 130 last night. Just wondering if I should go ahead and lower with acid/aeration or let it lower itself as it previously did. What causes this natural lowering?
    Rob
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: What causes TA to lower on its own
    It goes down anytime an acid is added to the pool. If you use trichlor pucks, that'll do it.
    Mar 2007
    San Rafael, CA USA
    12,082
    Also dilution with water that is lower in TA, though that doesn't sound like the case in this situation.
